Segnalare i giveaway sul sito?
winman
Re: Software commerciali in regalo
Messaggio da winman »
crazy.cat ha scritto:Wondershare video editor
http://turbolab.it/259
Molto facile e carino
Confermo ho usufruito a suo tempo del giveaway , un ottimo strumento :
sbrigatevi che fino al 5 aprile c'è un giveaway per Wondershare pdf editor :
http://www.mostiwant.com/blog/wondersha ... tion-code/
:wow
Win/Mac/Linux user
Has thanked: 4 times
Been thanked: 58 times
https://turbolab.it/282
[Claudio]
Messaggio da [Claudio] »
UpdateStar Premium Edition - multiligua - licenza 6 mesi - (software per l'aggiornamento dei ..... software).
Maggiori info: cliccare qui;
Pagina della promozione: cliccare qui.
[Claudio]
Se qualcuno è interessato:
1) Outpost Security Suite Pro: QUI PER LA PROMOZIONE;
2) GRT Data Recovery v2.1: QUI PER LA PROMOZIONE.
[Claudio]
Non si tratta di una versione commerciale, ma la segnalo comunque: Cyberlink Power2Go 9 Essential Free.
sondlive07
Messaggio da sondlive07 »
Perfect Effects 8 Premium Edition - FULL
Groucho Marx
sondlive07
emsisoft A-Squared Antimalware 8.1 (gratis 6 mesi)
webroot identity shield gratis 2 anni
Groucho Marx
[Claudio]
Silver Key Standard (100% discount):
Silver Key is an encryption program that uses AES 256-bit to produce encrypted files (or parcels) ideally suited for sending sensitive data over an insecure channel like the Internet.
Silver Key parcels are self-extracting, so the correspondent on the receiving end does not need to install any software to decrypt the file.
Portable version of Silver Key is included in this giveaway.
Terms and Conditions_
This is a 1-cojmputer lifetime license, for home use
No free updates; if you update the program, you may lose it
No free tech support
Must be installed and registered before this offer is over -- you cannot register later
May not be resold
No refunds and exchanges; if you are having trouble activating or registering, please ask for help
Supports_ Windows XP, Vista, Windows 7, and Windows 8 (32-bit and 64-bit)
Qui LA PROMOZIONE (restano 17 ora circa, da questa segnalazione).
Maggiori info sulle funzionalità della edizione proposta in promozione: QUI.
winman
http://sharewareonsale.com/shop
e http://mostiwant.com non perdeteveli !! :)
Tra tutte queste offerte periodiche non mi è sfuggito Kingsoft Office 2013 Pro , Wondeshare Pdf Editor con Ocr, Wondershare Video Editor e le offerte semestrali o annuali per il Panda e Bitdefender.
Win/Mac/Linux user
magopenguin
Messaggio da magopenguin »
9 months free of The BitDefender IS
Verificare
(Al momento ho lanciato il piccolo installer (c.ca 6 MB . Ha una firma digitale valida) mi ha disinstallato subito Avira e disabilitato il Firewall)
magopenguin
Edit:
Non si capisce come si attiva.
la mail con tanto di seriale mi è arrivata,ma rifiuta di attivarsi.
Inoltre noto un rallentamento globale dei sistema.
Al momento ,prima di fare un restore immagine (che già dovevo fare) sto navigando con Avast.
In alrtre parole:rimosso :!:
sondlive07
Bitdefender Internet Security 2015 (6 month FULL protection)
http://www.mostiwant.com/blog/avg-inter ... erial-key/
AVG Internet Security 2014 Free Download with 1 Year Serial Key
Groucho Marx
[Claudio]
ESET Mobile Security x Android, Win Mobile - Licenza 1 anno
Licenza di un anno per ESET Mobile Security (per Android, Windows Mobile e Symbian): CICCLARE QUI PER LA PROMOZIONE.
[Claudio]
IObit driver Booster PRO: licenza gratuita 6 mesi.
IObit driver Booster PRO gratis per sei mesi: [url=http://sharewareonsale. com/shop]CLICCARE QUI[/url]
Potete utilizzare un indirizzo email qualsiasi; la licenza viene mostrata nella pagina che si aprirà dopo aver inserito l'indirizzo email; il setup è quello della versione FREE, attivate la licenza con l'apposita funzione.
This is a 3-computer 6-month license, for home use. Want a longer license or business + home use? Get IObit Driver Booster PRO with free upgrades.
No free updates. Want free updates? Get IObit Driver Booster PRO with free upgrades.
No free tech support. Want free tech support? Get IObit Driver Booster PRO with free upgrades.
Must be downloaded, installed, and registered before this offer has ended -- you cannot register later. Want to install/reinstall and register at any time? Get IObit Driver Booster PRO with free upgrades.
May not be resold
Read more at http:// sharewareonsale. com/s/driver-booster-pro-iobit-sale#gVhK1J61psycBZdp.99
Tempo restante per la promozione (da questo momento): 1 giorno e 16 ore.
sondlive07
http://www.mostiwant.com/blog/panda-clo ... -download/
Panda Cloud Antivirus Pro Edition 3.0 Free Download 6 Months
Groucho Marx
Zemana antimalware v 2 beta - licenza a VITA
collegatevi qui
http://www.zemana.com/product/beta/register.aspx
seguite i passi (dovete iscrivervi al gruppo di Zemana su google, quindi è necessario un account e-mail gmail.com) quindi cliccate su next step, vedrete sia il vostro seriale - unico per ogni e-mail- e il link al download sia per la versione portatile sia per l'installer.
Al momento il programma è solo in inglese, e usa più motori antivirus quali ESET NOD32, Avira, Bitdefender, Microsoft etc, potete usare quelli che volete) e non offre una protezione in tempo reale.
Unica pecca a mio avviso è che si mette in esecuzione automatica da solo.
* se avete Hitmanpro installato suggerirei di rimuoverlo prima di proseguire
winman
leofelix ha scritto:Zemana antimalware v 2 beta - licenza a VITA
collegatevi qui
all'esecuzione automatica puoi ovviare da CCleaner > scheda strumenti > avvio e rimuovere la voce o almeno farlo dalle impostazioni del programma stesso. Può essere ideale invece sia portabili , pc e subnotebook o netbook a pare mio.
Win/Mac/Linux user
Sì, so come disattivarlo dalla esecuzione automatica, anche da comando msconfig è possibile farlo, grazie.
Non so dove tu abbia trovato l'opzione di non avviarsi con windows nel programma stesso, io ho solo "display tray notification" che può essere deselezionato, ma non rimuove dall'avvio Zemana Antimalware v 2 beta.
Probabilmente l'avvio automatico è dovuto ad altro come avveniva ad esempio per le prime versioni di lavasoft adaware 2007 beta e finali pur non offrendo all'epoca alcuna protezione in tempo reale (testai il programma, ma l'assistenza nel loro forum all'epoca era penosa).
Da quando ricordo Lavasoft ad-aware 2007 installava un servizio e relativo driver necessari al corretto funzionamento del programma, se disattivato dal'avvio automatico lavasoft adaware 2007 non funzionava più correttamente.
In ogni caso è disponbile la versione portabile.
Tu hai riscontrato problemi disattivando Zemana antimalware beta dall'avvio automatico?
sondlive07
diversi software in promozione
http://www.windowsdeal.com/category/giveaways/
Groucho Marx
sondlive07
Groucho Marx
winman
Aomei è super
Win/Mac/Linux user
carina2015
Messaggio da carina2015 »
è possibile ottenere il codice giveaway da qui.
http://www.apowersoft.it/promotion/
Re: Segnalare i giveaway sul sito?
TrustPort Total Security 2015 gratis per un anno.
La pagina della promozione è in polacco, si raggiunge tranquillamente anche dall'Italia
https://portal.trustport.com/promo/czchip2015
Traduzione in italiano
https://translate.google.com/translate? ... t=&act=url
suggerirei di togliere cliccare su "Ne" (no) alla voce finale "Souhlasím se zasíláním obchodních sdělení společnosti TrustPort. " allo scopo di evitare di ricevere mail promozionali e commerciali da parte della Trustport e in polacco.
La licenza arriva istantaneamente, ma non so entro quanto tempo può essere attivata (di solito queste licenze promozionali hanno un limite di tempo che varia da 15 a 30 giorni per essere attivate, non escludo nemmeno che il count down inizi dall'arrivo della mail col codice)
Il programma si installa anche in italiano, si può scaricare da qui
*http://www.trustport.com/download/file/ ... ection.exe
298 MB
Qui le caratteristiche
http://www.trustport.com/en/products/tr ... cteristics
Da quanto ricordo utilizza i motori di AVG, Bitdefender e credo anche Clamwin rinominati.
Non ho idea di che impatto abbia sul sistema, non l'ho ancora provato, so solo che nel 2013 avevo vinto una licenza di TrustPort Internet Security 2013 che avevo installato in un laptop con Windows 7 Home premium Intel Dual Core 2.1 Ghz, 4 GB RAM DDR 2, 500 HDD e avevo subito dei rallentamenti mostruosi tanto che dopo nemmeno due giorni avevo disinstallato il programma.
Va anche detto che ci sono due programmi che non mancano mai in nessuno dei miei sistemi (MalwareBytes' Antimalware premium e sandboxie) quindi non escludo che questi sistemi aggiuntivi di sicurezza possano aver influito sul rallentamento riscontrato.
Non sono nemmeno certo che io lo provi, visto che mi trovo benissimo o con Emsisoft (ottenuto grazie ai vostri giveaway) o con Panda antivirus free (leggerissimo anche se meno afficace come rilevazione oltre a non aver trovato modo di inviare alla Panda security campioni di malware direttamente)
In ogni caso chiunque possa essere interessato è bene che si affretti, queste promozioni di solito non durano a lungo
Spero di aver fatto cosa gradita :ciao
dimenticavo il codice per ottenere TrustPort
scusate sono un idiota, avevo dimenticato il codice promozionale per ottenere la licenza di TrustPort di cui parlavo nel post precedente, eccolo
CZCHIP2015TPTP
va inserito qui durante la richiesta alla voce Kód promoakce *:
sorry again
kevos
WonderFox DVD Video Converter gratis per un tempo limitato
Messaggio da kevos »
WonderFox DVD Video Converter fornisce una soluzione completa per rippare DVD (compresi quelli rilasciati da Disney, Paramount, Sony ecc.), convertire video, scaricare video online, modificare e riprodurre filmati con prestazioni eccellenti. Oltre alla potente tecnologia di decrittazione dei DVD, questo convertitore offre una velocità e una qualità di conversione superiori alla media.
http://www.videoconverterfactory.com/giveaway.html?tr
Per ottenere una licenza gratuita di WonderFox DVD Video Converter, andare in questa pagina, fare clic su "Get It Now" per scaricare.
